Inleiding
This guide will help give direction to properly remove the hard drive from your HP Pavilion Wave Desktop PC. Tools required for this removal might be a Phillips and Torx head screwdriver, metal and plastic prying tool, and a magnetic arrangement pad.
Wat je nodig hebt
Remove the three rubber footings by prying from the bottom cover using the plastic opening tool.
5 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
Why isn't there any information regarding cloning or transferring the original HDD and RECOVERY (D:) partition to the SSD. After my ssd upgrade I tried to use the recovery media and it would not work.. The portion or removal and replacing was pretty much spot on especially if you have done this type of thing before. (At least in my opinion)
Were you able to clone the HDD to your SSD? How about recovery? Also, is it possible and are there enough room for SSD and HDD? Please share your experience. Thank you!
my pc boots from a 250GB SSD drive, and has a 500 GB D: drive that I installed most programs on. I need to replace the SSD drive with a bigger one. The HDD drive is just fine. Where's the SSD located, in relation to the HDD?
