Ga door naar hoofdinhoud
HP Pavilion Wave 600-a010 Microphone Replacement
Wat je nodig hebt
  1. HP Pavilion Wave 600-a010 Microphone Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Remove the three rubber footings by prying from the bottom cover using the plastic opening tool.
  2. HP Pavilion Wave 600-a010 Microphone Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 24 mm screws from the bottom cover using a Phillips #2 screwdriver.
  3. HP Pavilion Wave 600-a010 Microphone Replacement: stap 3, afbeelding 1 van 1
    • Remove the bottom cover by lifting it up from chassis.
  4. HP Pavilion Wave 600-a010 Microphone Replacement: stap 4, afbeelding 1 van 1
    • Remove the three wires connecting the outer cover and front I/O port to the internal components (front usb and auxiliary assembly).
  5. HP Pavilion Wave 600-a010 Microphone Replacement: stap 5, afbeelding 1 van 2 HP Pavilion Wave 600-a010 Microphone Replacement: stap 5, afbeelding 2 van 2
    • Remove the outer cover by gently pulling apart and pulling away from the chassis.
  6. HP Pavilion Wave 600-a010 Microphone Replacement: stap 6, afbeelding 1 van 2 HP Pavilion Wave 600-a010 Microphone Replacement: stap 6, afbeelding 2 van 2
    • Remove rear I/O bezel using plastic opening tool to pry apart the four clips holding the I/O bezel to the chassis.
    • Remove all other remaining cables from unit using the plastic opening tool to carefully pry apart the connections.
  7. HP Pavilion Wave 600-a010 Microphone Replacement: stap 8, afbeelding 1 van 2 HP Pavilion Wave 600-a010 Microphone Replacement: stap 8, afbeelding 2 van 2
    • Remove the HDD by first using the Phillips #2 screwdriver to remove the four 23 mm screws holding together the assembly and then pulling the HDD out of the chassis.
  8. HP Pavilion Wave 600-a010 Microphone Replacement, Microphone: stap 9, afbeelding 1 van 1
    • Remove the three 24 mm screws that connect the top cover to the chasis inside the HDD compartment using theTorx #15 screwdriver (an extension and torque lever might be useful).
  9. HP Pavilion Wave 600-a010 Microphone Replacement: stap 10, afbeelding 1 van 1
    • Disconnect the microphone computer chip from the internal components by first peeling away the black adhesive holding the wires to the chassis and gently pulling the chip and wires from its connection.
  10. HP Pavilion Wave 600-a010 Microphone Replacement: stap 11, afbeelding 1 van 2 HP Pavilion Wave 600-a010 Microphone Replacement: stap 11, afbeelding 2 van 2
    • Remove the top bezel from the unit using a Torx Head #15 screwdriver to remove three 24 mm screws and a Phillips Head #00 screwdriver to remove the single 24 mm screw around the outside edge of the chassis.
Conclusie
clayton stokes
652 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 382
