Ga door naar hoofdinhoud
HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement
Wat je nodig hebt
  1. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Remove back plate: stap 2, afbeelding 1 van 1
    • Using a spudger, pry the plastic plate off of the base of the computer.
  3. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Remove screws: stap 3, afbeelding 1 van 1
    • Remove the screws from the WLAN card
  4. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Remove WLAN card: stap 4, afbeelding 1 van 1
    • Remove the card by sliding out of the slot.
  5. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Disconnect the cables: stap 5, afbeelding 1 van 1
    • Remove the cables from their connections by pulling them off. They should snap on and off.
Conclusie
Nguyen
295 Reputatie
2 handleidingen geschreven
Cal Poly, Team 21-22, Maness Winter 2015 Lid van Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 444
