Ga door naar hoofdinhoud
HP Pavilion Touchsmart 11z-e000 Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Keyboard: stap 2, afbeelding 1 van 1
    • Use a spudger to slide under the outer plastic cover of the laptop and lift it up and away.
    • Pull off the plastic cover of the laptop.
  3. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Remove all of the silver screws connecting the keyboard plate to the rest of the laptop.
    • This step allows the top plate to be removed from the body of the laptop in the following step.
  4. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Use a spudger to lift the keyboard plate off of the base of the computer.
    • Some areas near the hinges may be connected with an adhesive. Take care when removing the plate in these regions.
  5. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the screws connecting the keyboard to the underside of the plate
    • Detach the ribbon wire connecting the keyboard to the hardware.
    • This picture shows the underside of the keyboard after it is removed from the laptop.
  6. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Slowly separate the main part of the keyboard from the metal plate by pressing firmly on the key side of the keyboard and lifting from the back side.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Robert Hemphill
269 Reputatie
2 handleidingen geschreven
Cal Poly, Team 21-22, Maness Winter 2015 Lid van Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Leden
6 handleidingen geschreven
Één opmerking
Where can I find a replacement keyboard for the hp pavilion ts 11-e110nr? I've tried a basic search and also Amazon and eBay, but I can't find one anywhere.
Con Fran - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 1,684
