Ga door naar hoofdinhoud
HP Pavilion Touchsmart 11z-e000 Fan Replacement
Wat je nodig hebt
  1. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Fan Replacement, Fan: stap 2, afbeelding 1 van 1
    • Slide a spudger under the outer plastic cover of the laptop.
    • Pry the outer plastic cover off of the laptop, one side at a time.
    • Prying the outer plastic cover off may take a significant amount of force.
  3. HP Pavilion Touchsmart 11z-e000 Fan Replacement: stap 3, afbeelding 1 van 1
    • Unscrew all screws attaching the fan to the metal backboard.
  4. HP Pavilion Touchsmart 11z-e000 Fan Replacement: stap 4, afbeelding 1 van 1
    • Turn the laptop over.
    • Slide a spudger in between the outer plastic cover of the keyboard and the main body of the laptop.
    • Pry the top plastic cover off of the laptop.
    • Prying the outer plastic cover off may take a significant amount of force. Be careful!
  5. HP Pavilion Touchsmart 11z-e000 Fan Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the two screws that keep the fan in place.
  6. HP Pavilion Touchsmart 11z-e000 Fan Replacement: stap 6, afbeelding 1 van 1
    • Unplug the fan from the circuit board as shown
    • Carefully peel the tape connecting the fan and pull out the fan from the laptop.
Conclusie
Nguyen
295 Reputatie
2 handleidingen geschreven
Cal Poly, Team 21-22, Maness Winter 2015 Lid van Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 1,071
