Ga door naar hoofdinhoud
HP Pavilion Touchsmart 10-e010nr Battery Replacement
  1. HP Pavilion Touchsmart 10-e010nr Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off device and place with battery facing up.
    • Ensure that your hands are not wet, even if the laptop is off or dead.
  2. HP Pavilion Touchsmart 10-e010nr Battery Replacement: stap 2, afbeelding 1 van 2 HP Pavilion Touchsmart 10-e010nr Battery Replacement: stap 2, afbeelding 2 van 2
    • Push slider on left-hand side of device into unlocked position. This slider is not spring loaded so it should stay in position afterwards.
  3. HP Pavilion Touchsmart 10-e010nr Battery Replacement: stap 3, afbeelding 1 van 2 HP Pavilion Touchsmart 10-e010nr Battery Replacement: stap 3, afbeelding 2 van 2
    • Push in right-hand slider with your thumb and simultaneously apply slight pressure away from your body.
    • It may be helpful to keep your left thumb on the left slider and push with both thumbs.
  4. HP Pavilion Touchsmart 10-e010nr Battery Replacement: stap 4, afbeelding 1 van 2 HP Pavilion Touchsmart 10-e010nr Battery Replacement: stap 4, afbeelding 2 van 2
    • Battery should easily separate from main device.
Conclusie
Sean
159 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 462
