Ga door naar hoofdinhoud
HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Remove the battery from the device and unplug it.
    • Keep different sized screws separated from each other during disassembly and reassembly.
  2. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the two screws on the small back cover.
    • Remove the cover.
    • Remove the three screws that have been uncovered.
  3. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove the two rubber screw covers by the rubber feet of the device.
    • Using a Phillips #0 screwdriver, remove the two screws that have been uncovered.
  4. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the eight screws as directed.
    • Using a Phillips #1 screwdriver, remove the two remaining screws.
  5. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: stap 5, afbeelding 1 van 2 HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Using the plastic opening tool, gently pull up the keyboard starting from the bottom left corner, working your way to the bottom right corner.
    • To remove the keyboard, lift up the plastic retaining tab with the opening tool and gently pull out the ribbon wire.
  6. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Remove the plastic cover of the laptop using the opening tool.
    • The plastic cover is fragile, be cautious during removal.
  7. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • Using the plastic opening tool, pull up the retaining tab and and pull out the ribbon wire
    • This port is fragile, take care in removing and reinserting the ribbon wire.
  8. HP Pavilion TouchSmart 14z-n100 Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the six screws on the hard drive, then remove it.
    • Be sure to properly dispose or recycle your hard drive.
Conclusie
Justin Hurley
1 Reputatie
1 Handleiding geschreven
IUPUI, Team S6-G6, Wilson Spring 2019 Lid van IUPUI, Team S6-G6, Wilson Spring 2019
IUPUI-WILSON-S19S6G6
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 23
Altijd: 386
