Ga door naar hoofdinhoud
HP Pavilion TPN-C125 RAM Replacement
Wat je nodig hebt
  1. HP Pavilion TPN-C125 RAM Replacement, RAM: stap 1, afbeelding 1 van 2 HP Pavilion TPN-C125 RAM Replacement, RAM: stap 1, afbeelding 2 van 2
    • Flip the laptop over so the bottom is facing up and the external battery is at the top.
  2. HP Pavilion TPN-C125 RAM Replacement: stap 2, afbeelding 1 van 2 HP Pavilion TPN-C125 RAM Replacement: stap 2, afbeelding 2 van 2
    • Use your thumbs to slide the battery locks towards the center and pop the battery out.
  3. HP Pavilion TPN-C125 RAM Replacement: stap 3, afbeelding 1 van 2 HP Pavilion TPN-C125 RAM Replacement: stap 3, afbeelding 2 van 2
    • Slowly peel off the two rubber stoppers found at the top corners of the laptop.
    • This will expose two Philips #00 10 mm screws required to remove the back plate.
    • Be careful not to peel off the rubber stoppers too quickly as it could cause the adhesive on the rubber stopper to strip off.
  4. HP Pavilion TPN-C125 RAM Replacement: stap 4, afbeelding 1 van 2 HP Pavilion TPN-C125 RAM Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the twelve 10 mm screws (from the twelve holes shown) that secure the bottom case.
    • Use an opening tool to carefully separate the back case from the chassis, working around all four sides.
    • You will hear a "click" as you release the clips and remove it.
  5. HP Pavilion TPN-C125 RAM Replacement: stap 5, afbeelding 1 van 3 HP Pavilion TPN-C125 RAM Replacement: stap 5, afbeelding 2 van 3 HP Pavilion TPN-C125 RAM Replacement: stap 5, afbeelding 3 van 3
    • The RAM sticks can be found in the bottom right section of the laptop.
    • Push both side arms holding the RAM stick in place outwards.
    • The RAM sticks will "pop" up at a 45-degree angle when released from the arms.
    • Slide the RAM sticks out of the socket gently.
  6. HP Pavilion TPN-C125 RAM Replacement: stap 6, afbeelding 1 van 3 HP Pavilion TPN-C125 RAM Replacement: stap 6, afbeelding 2 van 3 HP Pavilion TPN-C125 RAM Replacement: stap 6, afbeelding 3 van 3
    • Carefully slide the new replacement RAM sticks into their slots.
    • Make sure to align edge of the RAM sticks with the slots to avoid damaging both.
    • Gently push the RAM sticks downward until the latches click into place to secure them.
Conclusie
Cesar Gomez
183 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 57
Altijd: 132
