Inleiding
This guide will go through the steps to replace the speakers if the audio is distorted or the sounds is not working.
Wat je nodig hebt
Using the spudger to lift up on the white tabs
Pull horizontally on the blue ribbon to disconnect the cables
Use a plastic opening tool to carefully remove the right speaker.
Repeat this step for the left speaker.
Bijna klaar!
Conclusie
