Ga door naar hoofdinhoud
HP Pavilion Sleekbook 15-b000 Screen Replacement
Wat je nodig hebt
  1. HP Pavilion Sleekbook 15-b000 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 3, afbeelding 1 van 2 HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 3, afbeelding 2 van 2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 4, afbeelding 1 van 1
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 Screen Replacement, Keyboard: stap 5, afbeelding 1 van 1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 6, afbeelding 1 van 1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 7, afbeelding 1 van 1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 8, afbeelding 1 van 1
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15-b000 Screen Replacement, Case: stap 9, afbeelding 1 van 1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 10, afbeelding 1 van 1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 11, afbeelding 1 van 1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 12, afbeelding 1 van 3 HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 12, afbeelding 2 van 3 HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 12, afbeelding 3 van 3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15-b000 Screen Replacement, Screen: stap 13, afbeelding 1 van 1
    • Remove the four 5.5mm Phillips #1 screws attaching the screen.
  14. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 14, afbeelding 1 van 1
    • Remove the two 3.5mm Phillips #1 screws from the bottom of the screen.
  15. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 15, afbeelding 1 van 1
    • Remove the screen from it's case.
    • Screen is still connected to it's case by a wire.
  16. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 16, afbeelding 1 van 1
    • Lay the screen face down on a surface where it ill not scratch
  17. HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 17, afbeelding 1 van 2 HP Pavilion Sleekbook 15-b000 Screen Replacement: stap 17, afbeelding 2 van 2
    • Lift up plastic over latch for the screen.
    • Pull the connector away from the screen to disconnect it.
Conclusie
Sam Barkley
983 Reputatie
8 handleidingen geschreven
USF Tampa, Team S11-G2, Cheng Spring 2018 Lid van USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 241
