Inleiding
Since the operating system is stored in the hard drive, the laptop may not start or boot if the hard drive is faulty or not working. This guide will take you through the steps to remove the hard drive from your laptop in case the laptop will not boot or having problems loading to your desktop.
Wat je nodig hebt
Using the spudger to lift up on the white tabs
Pull horizontally on the blue ribbon to disconnect the cables
Bijna klaar!
Conclusie
