Ga door naar hoofdinhoud
HP Pavilion Sleekbook 15- b000 Fan
Wat je nodig hebt
  1. HP Pavilion Sleekbook 15- b000 Fan, Battery: stap 1, afbeelding 1 van 1
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15- b000 Fan: stap 2, afbeelding 1 van 1
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15- b000 Fan: stap 3, afbeelding 1 van 2 HP Pavilion Sleekbook 15- b000 Fan: stap 3, afbeelding 2 van 2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15- b000 Fan: stap 4, afbeelding 1 van 1
    • Pull battery out.
  5. HP Pavilion Sleekbook 15- b000 Fan, Keyboard: stap 5, afbeelding 1 van 1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15- b000 Fan: stap 6, afbeelding 1 van 1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15- b000 Fan: stap 7, afbeelding 1 van 1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15- b000 Fan: stap 8, afbeelding 1 van 1
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15- b000 Fan, Case: stap 9, afbeelding 1 van 1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15- b000 Fan: stap 10, afbeelding 1 van 1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15- b000 Fan: stap 11, afbeelding 1 van 1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15- b000 Fan: stap 12, afbeelding 1 van 3 HP Pavilion Sleekbook 15- b000 Fan: stap 12, afbeelding 2 van 3 HP Pavilion Sleekbook 15- b000 Fan: stap 12, afbeelding 3 van 3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15- b000 Fan, Fan: stap 13, afbeelding 1 van 1
    • Remove the three x 5.5 mm restraining screws.
  14. HP Pavilion Sleekbook 15- b000 Fan: stap 14, afbeelding 1 van 1
    • Pull fan of of heat pipe.
  15. HP Pavilion Sleekbook 15- b000 Fan: stap 15, afbeelding 1 van 1
    • Remove fan.
Conclusie
Sam Barkley
983 Reputatie
8 handleidingen geschreven
USF Tampa, Team S11-G2, Cheng Spring 2018 Lid van USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 383
