Ga door naar hoofdinhoud
HP Pavilion Sleekbook 14-b013cl Screen Replacement
Wat je nodig hebt
  1. HP Pavilion Sleekbook 14-b013cl Screen Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Screen Replacement: stap 2, afbeelding 1 van 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement: stap 2, afbeelding 2 van 2
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Screen Replacement: stap 3, afbeelding 1 van 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement: stap 3, afbeelding 2 van 2
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: stap 4, afbeelding 1 van 3 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: stap 4, afbeelding 2 van 3 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: stap 4, afbeelding 3 van 3
    • Using a 1.0 Flathead screwdriver, remove the two stickers covering the screws that hold the screen in place.
    • Use a Phillips #1 screwdriver to remove the two 3.2mm screws that are now visible.
  5. HP Pavilion Sleekbook 14-b013cl Screen Replacement: stap 5, afbeelding 1 van 3 HP Pavilion Sleekbook 14-b013cl Screen Replacement: stap 5, afbeelding 2 van 3 HP Pavilion Sleekbook 14-b013cl Screen Replacement: stap 5, afbeelding 3 van 3
    • Using a plastic opening tool, pry the plastic screen protector off, sliding the tool along the seam. Press the tool in until you hear the plastic tabs clicking as they come undone.
    • Separate the plastic that makes up the hinges for the screen, as they are part of the same screen protector.
    • Use your hands or plastic tool to peel the screen protector away from the adhesive holding it in place.
  6. HP Pavilion Sleekbook 14-b013cl Screen Replacement: stap 6, afbeelding 1 van 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement: stap 6, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the six 2.8mm screws holding the screen in place.
    • Lift the screen away from the cover until you have access to the connector cable near the bottom of the screen.
  7. HP Pavilion Sleekbook 14-b013cl Screen Replacement: stap 7, afbeelding 1 van 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement: stap 7, afbeelding 2 van 2
    • Peel away any sticker holding the connector in place and simply pull the tab out of the connector parallel with the screen.
    • Remove the screen from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 485
