Ga door naar hoofdinhoud
HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement
Wat je nodig hebt
  1. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement, RAM: stap 1, afbeelding 1 van 1
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: stap 2, afbeelding 1 van 2 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: stap 2, afbeelding 2 van 2
    • Using the 1.5 Phillips #1 screwdriver, loosen the 7 screws.
  3. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: stap 3, afbeelding 1 van 3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: stap 3, afbeelding 2 van 3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: stap 3, afbeelding 3 van 3
    • Insert the metal opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case.
    • Remove the back case.
    • When removing the back plate, use caution, removing slowly in order to not break the clips.
  4. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: stap 4, afbeelding 1 van 3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: stap 4, afbeelding 2 van 3 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: stap 4, afbeelding 3 van 3
    • Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it.
    • With your fingers, push on the Ram stick until the metal arms are not holding the stick.
    • The RAM will pop up by a few millimeters up.
    • Remove it by pulling straight towards you and not a angle so you don't damage the socket.
  5. HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: stap 5, afbeelding 1 van 2 HP Pavilion Gaming Laptop 15-dk2xxx RAM Replacement: stap 5, afbeelding 2 van 2
    • Slide the RAM stick out from the memory module slot.
    • Repeat for the RAM stick located below. This computer had RAM in the slot below.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Anthony Padilla
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 49
Altijd: 180
