Ga door naar hoofdinhoud
HP Pavilion G7-2289wm Optical Drive Replacement
Wat je nodig hebt
  1. HP Pavilion G7-2289wm Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Optical Drive Replacement, Optical Drive: stap 2, afbeelding 1 van 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Optical Drive Replacement: stap 3, afbeelding 1 van 2 HP Pavilion G7-2289wm Optical Drive Replacement: stap 3, afbeelding 2 van 2
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
Conclusie
Ryson Smith
636 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 273
