Ga door naar hoofdinhoud
HP Pavilion G7-2235DX Screen Replacement
Wat je nodig hebt
  1. HP Pavilion G7-2235DX Screen Replacement, Fan: stap 1, afbeelding 1 van 1
    • Flip the laptop over and remove six 7.25mm screws.
  2. HP Pavilion G7-2235DX Screen Replacement: stap 2, afbeelding 1 van 2 HP Pavilion G7-2235DX Screen Replacement: stap 2, afbeelding 2 van 2
    • Using the plastic opening tool or spudger, separate the keyboard from the frame of the laptop.
    • Gently pull the keyboard away from the laptop, toward you, until it is completely separated from the laptop.
  3. HP Pavilion G7-2235DX Screen Replacement: stap 3, afbeelding 1 van 2 HP Pavilion G7-2235DX Screen Replacement: stap 3, afbeelding 2 van 2
    • Remove the four 7.25mm screws located by the red markers.
  4. HP Pavilion G7-2235DX Screen Replacement: stap 4, afbeelding 1 van 2 HP Pavilion G7-2235DX Screen Replacement: stap 4, afbeelding 2 van 2
    • Gently lift the panel up, exposing the inside of the laptop.
  5. HP Pavilion G7-2235DX Screen Replacement: stap 5, afbeelding 1 van 2 HP Pavilion G7-2235DX Screen Replacement: stap 5, afbeelding 2 van 2
    • The fan is located in the top, left hand corner. Now, it can be gently lifted out using your hands.
  6. HP Pavilion G7-2235DX Screen Replacement, Screen: stap 6, afbeelding 1 van 1
    • To remove the laptop's screen, you will have to remove a total of four 7.25mm screws.
    • First, remove the two 7.25mm screws found in the upper right corner as shown.
  7. HP Pavilion G7-2235DX Screen Replacement: stap 7, afbeelding 1 van 2 HP Pavilion G7-2235DX Screen Replacement: stap 7, afbeelding 2 van 2
    • Next, unscrew the two 7.25mm screws in the upper left corner of the laptop as shown.
  8. HP Pavilion G7-2235DX Screen Replacement: stap 8, afbeelding 1 van 2 HP Pavilion G7-2235DX Screen Replacement: stap 8, afbeelding 2 van 2
    • Once all of the screws have been removed, gently lift the laptop's screen from the base of the computer.
Conclusie
Bre'Anna Sanders
113 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-7, Leahy Fall 2016 Lid van USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 451
