Ga door naar hoofdinhoud
HP Pavilion G60-235DX Keyboard Replacement
Wat je nodig hebt
  1. HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: stap 1, afbeelding 1 van 2 HP Pavilion G60-235DX Keyboard  Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Please turn the power of your device off. If not, it may cause a damage to the computer's hard drive and the person.
    • Slide the lock to remove the battery
    • After removing the battery, you can find 8 screws where battery were placed. Unscrew those 8 screws.
  2. HP Pavilion G60-235DX Keyboard  Replacement: stap 2, afbeelding 1 van 3 HP Pavilion G60-235DX Keyboard  Replacement: stap 2, afbeelding 2 van 3 HP Pavilion G60-235DX Keyboard  Replacement: stap 2, afbeelding 3 van 3
    • Do not force if the frame is not coming out. It may break the clip of the frame.
    • After the screws from battery house are removed, open the laptop to remove the keyboard frame.
    • Approach the frame on the side by using the prying tool. Carefully remove the clip. Watch out not to break the clip.
    • Then use the prying tool to carefully remove the frame from the top. Be careful not to break the clip.
    • Then, press the button located top of the touch pad to completely remove the frame from the bottom of the frame.
  3. HP Pavilion G60-235DX Keyboard  Replacement: stap 3, afbeelding 1 van 1
    • When the frame is removed, keyboard will be free to be removed. There is cable ribbon to be removed. Gently pull out the ribbon from where it is plugged.
    • The keyboard is now detached from the computer.
Conclusie
Gilbert Han
241 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-5, Banghart Winter 2017 Lid van Cal Poly, Team 10-5, Banghart Winter 2017
CPSU-BANGHART-W17S10G5
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 481
