Wat je nodig hebt
Using the Phillips #0 screwdriver, remove the seven 4.0mm screws on the battery compartment of the laptop.
Insert an opening tool into the top right side of the corner, and gently lift the rest of the cover to separate if from the laptop.
Using the Phillips #0 screwdriver, remove the four 4mm screws from the midframe.
Één andere persoon heeft deze handleiding voltooid.
