Inleiding
This guide shows how to go about removing the display assembly from the HP Pavilion G60-120US and installing a replacement. This will also enable users to access multiple parts of the laptop.
Wat je nodig hebt
Using the Phillips #0 screwdriver, remove the seven 4.0mm screws on the battery compartment of the laptop.
Insert an opening tool into the top right side of the corner, and gently lift the rest of the cover to separate if from the laptop.
