Ga door naar hoofdinhoud
HP Pavilion G6-1d16dx Wireless Card Replacement
Wat je nodig hebt
  1. HP Pavilion G6-1d16dx Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
  2. HP Pavilion G6-1d16dx Wireless Card Replacement: stap 2, afbeelding 1 van 1
    • Slide the switch under the battery compartment to release the battery.
  3. HP Pavilion G6-1d16dx Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery.
    • The battery will have popped out of the compartment when it was released.
  4. HP Pavilion G6-1d16dx Wireless Card Replacement, Wireless Card: stap 4, afbeelding 1 van 2 HP Pavilion G6-1d16dx Wireless Card Replacement, Wireless Card: stap 4, afbeelding 2 van 2
    • Unscrew the two captive screws using the Phillips #000 screwdriver.
    • The screws will not come all the way out; stop when you hear them click.
    • Unsnap the protective cover off of the device.
    • Locate the wireless card.
  5. HP Pavilion G6-1d16dx Wireless Card Replacement: stap 5, afbeelding 1 van 2 HP Pavilion G6-1d16dx Wireless Card Replacement: stap 5, afbeelding 2 van 2
    • Remove the two screws located on the corners of the wireless card, using the Phillips #000 screwdriver.
    • Slide the Wi-Fi card out of the socket.
  6. HP Pavilion G6-1d16dx Wireless Card Replacement: stap 6, afbeelding 1 van 1
    • Using your fingers, unsnap the coaxial cable wires from the wireless card.
    • Connect them to the new card based on the attachment points.
    • These points are indicated by numbered tabs. For example, wire #1 connects to #1 on the wireless card.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 38
Altijd: 1,444
