Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
Slide the switch under the battery compartment to release the battery.
Unscrew the two silver screws holding the protective cover in place until they make a clicking noise.
Unsnap the cover by lifting the edge along the battery compartment.
Push the two tabs on the sides of the RAM compartment away from the memory stick.
After the tabs are moved, the RAM stick will pop up, and you can pull the card straight out of its slot.
Één andere persoon heeft deze handleiding voltooid.
