Ga door naar hoofdinhoud
HP Pavilion DV9700 RAM Replacement
Wat je nodig hebt
  1. HP Pavilion DV9700 RAM Replacement, RAM: stap 1, afbeelding 1 van 2 HP Pavilion DV9700 RAM Replacement, RAM: stap 1, afbeelding 2 van 2
    • Turn the device over so that the bottom is facing upward.
    • Locate the three panels near the bottom half of the device.
    • The middle-most panel is the one we will be focusing on.
    • Using a Philips #0 screwdriver, unscrew the two 4mm screws that hold this panel in place.
  2. HP Pavilion DV9700 RAM Replacement: stap 2, afbeelding 1 van 2 HP Pavilion DV9700 RAM Replacement: stap 2, afbeelding 2 van 2
    • Pull the bottom of the panel upward.
    • Then pull the panel toward yourself to remove.
  3. HP Pavilion DV9700 RAM Replacement: stap 3, afbeelding 1 van 3 HP Pavilion DV9700 RAM Replacement: stap 3, afbeelding 2 van 3 HP Pavilion DV9700 RAM Replacement: stap 3, afbeelding 3 van 3
    • Look toward the top half of the exposed compartment.
    • Each ram stick will have two silver clips on the left and right side.
    • Push these clips outward at the same time to release the ram stick.
  4. HP Pavilion DV9700 RAM Replacement: stap 4, afbeelding 1 van 3 HP Pavilion DV9700 RAM Replacement: stap 4, afbeelding 2 van 3 HP Pavilion DV9700 RAM Replacement: stap 4, afbeelding 3 van 3
    • The ram stick will be held at a 45 degree angle. Pull the stick upward to release it from the slot.
    • Each ram stick will have a notch near the bottom, make sure to keep note of which side this notch is on.
    • Make sure to place the ram away from any static surfaces (carpet, fabric, etc.)
Conclusie
Max Shangraw
507 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S6-G1, Bernier Spring 2018 Lid van UMass Dartmouth, Team S6-G1, Bernier Spring 2018
UMASSD-BERNIER-S18S6G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 771
