Ga door naar hoofdinhoud
HP Pavilion DV9700 Optical Drive Replacement
Wat je nodig hebt
  1. HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: stap 1, afbeelding 1 van 3 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: stap 1, afbeelding 2 van 3 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: stap 1, afbeelding 3 van 3
    • Turn the device over so that the bottom is facing upward.
    • Find the screw with an imprint of a disk underneath it. It is located near the center of the device.
    • Remove this 6mm screw with a Philips #0 screwdriver.
    • This screw is very small, make sure to have an organized place to put it.
  2. HP Pavilion DV9700 Optical Drive  Replacement: stap 2, afbeelding 1 van 3 HP Pavilion DV9700 Optical Drive  Replacement: stap 2, afbeelding 2 van 3 HP Pavilion DV9700 Optical Drive  Replacement: stap 2, afbeelding 3 van 3
    • The optical drive is located toward the left side of the device.
    • Using a spudger, pry the optical drive away from the casing.
    • Pull the rest of the optical drive out with your hand.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Max Shangraw
507 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S6-G1, Bernier Spring 2018 Lid van UMass Dartmouth, Team S6-G1, Bernier Spring 2018
UMASSD-BERNIER-S18S6G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 358
