Ga door naar hoofdinhoud
HP Pavilion DV9700 Digital Media Control Panel Replacement
Wat je nodig hebt
  1. HP Pavilion DV9700 Digital Media Control Panel  Replacement, Digital Media Control Panel: stap 1, afbeelding 1 van 2 HP Pavilion DV9700 Digital Media Control Panel  Replacement, Digital Media Control Panel: stap 1, afbeelding 2 van 2
    • First turn the device so that the back is facing upward.
    • There is a tab located near the top left portion of the device.
    • Push the tab and pull the battery upward to remove the battery from the device.
  2. HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 2, afbeelding 1 van 2 HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 2, afbeelding 2 van 2
    • In the battery compartment there are 6 4mm screws.
    • Unscrew these screws using a Philips #0 head screwdriver.
    • These screws are very small, make sure to have an organized place to put them.
  3. HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 3, afbeelding 1 van 3 HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 3, afbeelding 2 van 3 HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 3, afbeelding 3 van 3
    • Turn the laptop over to it's resting position.
    • Open the laptop and locate the media bar across the top of the keyboard.
    • On the left side of the media bar, insert a spudger under the media bar near the top.
    • Move the spudger toward the bottom of the media bar, releasing the clips.
  4. HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 4, afbeelding 1 van 3 HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 4, afbeelding 2 van 3 HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 4, afbeelding 3 van 3
    • On the right of the media bar insert the spudger near the top.
    • Move the spudger toward the bottom of the media to release the clips
  5. HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 5, afbeelding 1 van 2 HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 5, afbeelding 2 van 2
    • Carefully pull the media bar upward about an inch.
    • Flip the media bar toward yourself to expose the cable still attached.
    • Make sure not to pull the media bar too far away from the device. This could cause damage to the cable or the cable port.
  6. HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 6, afbeelding 1 van 3 HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 6, afbeelding 2 van 3 HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 6, afbeelding 3 van 3
    • The ribbon cable is located near the left side of the media bar.
    • The ribbon cable is held down by a brown clip.
    • Using a fingernail pry one of the sides of the clip to release it.
    • The clip is fragile, be careful not to use too much pressure.
  7. HP Pavilion DV9700 Digital Media Control Panel  Replacement: stap 7, afbeelding 1 van 1
    • With the ribbon cable successfully detached you may now replace the media bar with a new, functioning one.
Conclusie
Max Shangraw
507 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S6-G1, Bernier Spring 2018 Lid van UMass Dartmouth, Team S6-G1, Bernier Spring 2018
UMASSD-BERNIER-S18S6G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 595
