Ga door naar hoofdinhoud
HP Pavilion DV5T-1000 Hard Drive Replacement
Wat je nodig hebt
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  1. HP Pavilion DV5T-1000 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion DV5T-1000.
  2. HP Pavilion DV5T-1000 Hard Drive Replacement: stap 3, afbeelding 1 van 2 HP Pavilion DV5T-1000 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Slide the battery lock to the left, it's located just below the battery compartment.
    • Pull the battery up and out, to remove it from the battery compartment.
    • To prevent hardware damage, remove the battery before working on the laptop.
  3. HP Pavilion DV5T-1000 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Identify the hard drive compartment, located at the top left-hand frame of the laptop.
  4. HP Pavilion DV5T-1000 Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • In order to remove the hard drive compartment cover, first remove the two screws located on the panel, using a size 0 Phillips head screwdriver.
  5. HP Pavilion DV5T-1000 Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Expose the hard drive by lifting the drive cover.
  6. HP Pavilion DV5T-1000 Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • In order to loosen the hard drive from the motherboard, tug gently on the black tabs located at both ends of the hard drive.
    • Be cautious when handling the cable that connects the hard drive to the computer's motherboard.
  7. HP Pavilion DV5T-1000 Hard Drive Replacement: stap 8, afbeelding 1 van 2 HP Pavilion DV5T-1000 Hard Drive Replacement: stap 8, afbeelding 2 van 2
    • Firmly hold both the black plug, and the hard drive itself to separate the drive from the cable.
  8. HP Pavilion DV5T-1000 Hard Drive Replacement: stap 9, afbeelding 1 van 2 HP Pavilion DV5T-1000 Hard Drive Replacement: stap 9, afbeelding 2 van 2
    • Remove the 4 screws using a size 0 Phillips head screwdriver.
    • Remove the metal from the perimeter of the hard drive.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Josh Taimanglo
147 Reputatie
1 Handleiding geschreven
Één opmerking
Help after replacing hard drive installation of windows
Bettyjean Serrano - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,901
