Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide instructs you how to remove the RAM. You will need the screwdriver listed in the tools section.
Wat je nodig hebt
Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
The yellow highlighted edge of the battery should pop up slightly when the switch is moved
Remove the two 3.5 mm diameter head and 7 mm long screws using the Philips PH1 screwdriver.
Set the cover with attached screws to the side.
The RAM will now be exposed
