Ga door naar hoofdinhoud
HP Pavilion DV3 Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion DV3 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 Hard Drive Replacement: stap 2, afbeelding 1 van 2 HP Pavilion DV3 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 1
    • Locate the screw for the hard drive cover (The cover has HP ProtectSmart written on it).
    • Remove the 3.5 mm diameter, 7 mm long screw with your Phillips PH1 screwdriver.
    • The screw will remain attached to the cover.
  4. HP Pavilion DV3 Hard Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion DV3 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Grab the raised edge of the cover lift up. This will separate the cover from the laptop.
    • Put the cover and screw to the.
    • This will reveal the hard drive.
  5. HP Pavilion DV3 Hard Drive Replacement: stap 5, afbeelding 1 van 3 HP Pavilion DV3 Hard Drive Replacement: stap 5, afbeelding 2 van 3 HP Pavilion DV3 Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • With your fingers, grab the clear tab.
    • Pull right first, and then upwards (towards you).
    • The hard drive should slide out of place and detach from the laptop.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Luke Whitmarsh
649 Reputatie
2 handleidingen geschreven
Cal Poly, Team 14-10, Forte Fall 2013 Lid van Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 45
Altijd: 5,335
