Ga door naar hoofdinhoud
HP Pavilion DV3 HP Pavilion Wireless Card Replacement
Wat je nodig hebt
  1. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: stap 2, afbeelding 1 van 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: stap 2, afbeelding 2 van 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Wireless Card: stap 3, afbeelding 1 van 1
    • With the laptop upside down, locate the three screws on the wireless card cover and unscrew the screws.
    • All three screws will have a 3.5 mm diameter head.
    • Two of the screws will be silver, 7mm in length, and will stay attached to the cover.
    • One screw will be black, 13mm in length, and will separate from the cover. Set this screw aside.
  4. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: stap 4, afbeelding 1 van 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: stap 4, afbeelding 2 van 2
    • Grab one of the edges to the cover and lift up (towards you).
    • Set the cover to the side.
    • The wireless card will now be exposed.
  5. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: stap 5, afbeelding 1 van 3 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: stap 5, afbeelding 2 van 3 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: stap 5, afbeelding 3 van 3
    • Using your hand, pull the black and white antenna wires upwards.
    • This will disconnect the antenna wires from the card.
  6. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: stap 6, afbeelding 1 van 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: stap 6, afbeelding 2 van 2
    • Locate the two black screws connecting the wireless card to the laptop. They will have a 3.5 mm diameter head and be 4mm long. Remove the screws.
    • Once the screws are removed, the wireless card will pop up.
  7. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: stap 7, afbeelding 1 van 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: stap 7, afbeelding 2 van 2
    • Grab the sides of the wireless card and pull it up and to the left to disconnect from the laptop.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brandon Baldovin
548 Reputatie
3 handleidingen geschreven
Cal Poly, Team 14-10, Forte Fall 2013 Lid van Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 1,638
