Ga door naar hoofdinhoud
HP Pavilion DV2160BR Wifi Adapter Replacement
Wat je nodig hebt
  1. HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: stap 1, afbeelding 1 van 2 HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: stap 1, afbeelding 2 van 2
    • Start with the bottom of the laptop facing up.
    • Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
    • Remove the panel and set it aside.
    • Be careful not to snap the 2 tabs on the sides of the panel when pulling it out.
  2. HP Pavilion DV2160BR Wifi Adapter Replacement: stap 2, afbeelding 1 van 2 HP Pavilion DV2160BR Wifi Adapter Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
  3. HP Pavilion DV2160BR Wifi Adapter Replacement: stap 3, afbeelding 1 van 2 HP Pavilion DV2160BR Wifi Adapter Replacement: stap 3, afbeelding 2 van 2
    • Pull the 2 black wires with the gold pieces out of the wifi adapter.
    • The wifi adapter is now free to be removed.
    • When reconnecting the wires for re-installing the wifi adapter, make sure the gold ends are rotated correctly to be properly pushed back in.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Shannon
55 Reputatie
6 handleidingen geschreven
Cal Poly, Team 13-66, Johann Spring 2013 Lid van Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 533
