Ga door naar hoofdinhoud
HP Pavilion DV2160BR Webcam Replacement
Wat je nodig hebt
  1. HP Pavilion DV2160BR Webcam Replacement, Battery: stap 1, afbeelding 1 van 1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR Webcam Replacement: stap 2, afbeelding 1 van 2 HP Pavilion DV2160BR Webcam Replacement: stap 2, afbeelding 2 van 2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR Webcam Replacement, Webcam: stap 3, afbeelding 1 van 1
    • Flip over the laptop and open it.
  4. HP Pavilion DV2160BR Webcam Replacement: stap 4, afbeelding 1 van 2 HP Pavilion DV2160BR Webcam Replacement: stap 4, afbeelding 2 van 2
    • Remove the 6 rubber screw covers from the screen panel using the plastic opener tools by applying firm pressure to the edges.
    • The 4 screw covers on top are attached by an adhesive backing.
    • The 2 screw covers on the bottom are rubber plugs.
  5. HP Pavilion DV2160BR Webcam Replacement: stap 5, afbeelding 1 van 1
    • Remove the 4 M2.5x4-Lg #0 Phillips screws from the top of the screen panel.
    • Remove the 2 M2.5x8-Lg #1 Phillips screws from the bottom of the screen panel.
  6. HP Pavilion DV2160BR Webcam Replacement: stap 6, afbeelding 1 van 2 HP Pavilion DV2160BR Webcam Replacement: stap 6, afbeelding 2 van 2
    • Slide a plastic opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
  7. HP Pavilion DV2160BR Webcam Replacement: stap 7, afbeelding 1 van 1
    • Locate the screw on the left side of the cameras mounting bracket.
    • Remove the M2.5x4-Lg #0 Phillips screw
  8. HP Pavilion DV2160BR Webcam Replacement: stap 8, afbeelding 1 van 1
    • Pull the camera from the back screen panel and rotate it so you are looking at the back.
    • Remove the 2 M2x3-Lg #00 Phillips screws and place the mounting bracket aside.
  9. HP Pavilion DV2160BR Webcam Replacement: stap 9, afbeelding 1 van 1
    • Disconnect the cable on the right side of the camera board by pulling firmly on the connector.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brandon MacDonald
239 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 Lid van UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G5
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 774
