Inleiding
Use this guide to replace a broken display assembly.
Wat je nodig hebt
Remove the 6 rubber screw covers and screws, found around the edge of the laptop screen, surrounded in red and blue.
Use the plastic opener tools to remove the screw covers. Just apply firm pressure to the edges to pop the screw covers out, they are attached with a light adhesive.
There are four 2.5mm X 4mm-L Phillips #0 screws along the top.
There are two 2.5mm X 8mm-L Phillips #1 screws along the bottom.
Remove the screen from the back screen panel.
Set the screen facing down gently onto the keyboard.
Now that the screen is placed face down onto the keyboard we are going to remove the wire connecting the screen to the device.
The wire is held on by an adhesive tape that must be lifted with the spudger tool.
Once the tape is lifted, slide your finger under and gently pull up the rest of the tape to free the wire.
Gently pull the wire towards the back of the device and the screen will now be free.
Één andere persoon heeft deze handleiding voltooid.
