Ga door naar hoofdinhoud
HP Pavilion DV2160BR RAM Replacement
Wat je nodig hebt
  1. HP Pavilion DV2160BR RAM Replacement, RAM: stap 1, afbeelding 1 van 2 HP Pavilion DV2160BR RAM Replacement, RAM: stap 1, afbeelding 2 van 2
    • Start with the bottom of the laptop facing up.
    • Locate the panel that is covering the RAM compartment.
    • Unscrew the two 5mm Phillips #0 screws that are securing the RAM compartment.
  2. HP Pavilion DV2160BR RAM Replacement: stap 2, afbeelding 1 van 2 HP Pavilion DV2160BR RAM Replacement: stap 2, afbeelding 2 van 2
    • Lift up the panel that is by the end that held the screws. Set it aside.
  3. HP Pavilion DV2160BR RAM Replacement: stap 3, afbeelding 1 van 3 HP Pavilion DV2160BR RAM Replacement: stap 3, afbeelding 2 van 3 HP Pavilion DV2160BR RAM Replacement: stap 3, afbeelding 3 van 3
    • Using 2 prying tools, push the 2 buttons on the sides of one RAM module simultaneously, so that one side of the module pops up and out of the clips holding it down.
    • Grab the RAM module and carefully pull it straight out of its slot.
    • Repeat this step for the second RAM module, which is located just underneath the first RAM module.
Conclusie
Shannon
55 Reputatie
6 handleidingen geschreven
Cal Poly, Team 13-66, Johann Spring 2013 Lid van Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 382
