Ga door naar hoofdinhoud
HP Pavilion DV2160BR DVD±RW Drive Replacement
Wat je nodig hebt
  1. HP Pavilion DV2160BR DVD±RW Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR DVD±RW Drive Replacement: stap 2, afbeelding 1 van 2 HP Pavilion DV2160BR DVD±RW Drive Replacement: stap 2, afbeelding 2 van 2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR DVD±RW Drive Replacement, DVD±RW Drive: stap 3, afbeelding 1 van 1
    • Locate the locking screw which is located in a recessed hole on the underside of the laptop.
    • Remove the M2.5X3-Lg #1 Phillips screw.
  4. HP Pavilion DV2160BR DVD±RW Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion DV2160BR DVD±RW Drive Replacement: stap 4, afbeelding 2 van 2
    • Locate the CD drive tray release hole on the front of the drive.
    • Straighten a paper clip and push it gently into the CD drive tray release hole.
    • The drive tray will pop open.
  5. HP Pavilion DV2160BR DVD±RW Drive Replacement: stap 5, afbeelding 1 van 1
    • Grasp the side edges of the drive tray.
    • Gently pull the drive from the laptop.
  6. HP Pavilion DV2160BR DVD±RW Drive Replacement: stap 6, afbeelding 1 van 1
    • Locate the mounting bracket which is attached to the back of the drive.
    • Remove the two M2x3-Lg #0 Phillips screws.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brandon MacDonald
239 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014 Lid van UMass Dartmouth, Team 6-5, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G5
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 243
