Ga door naar hoofdinhoud
HP Pavilion DV1000 Screen Replacement
Wat je nodig hebt
  1. HP Pavilion DV1000 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion DV1000 Screen Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop over.
  3. HP Pavilion DV1000 Screen Replacement: stap 3, afbeelding 1 van 2 HP Pavilion DV1000 Screen Replacement: stap 3, afbeelding 2 van 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion DV1000 Screen Replacement: stap 4, afbeelding 1 van 3 HP Pavilion DV1000 Screen Replacement: stap 4, afbeelding 2 van 3 HP Pavilion DV1000 Screen Replacement: stap 4, afbeelding 3 van 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion DV1000 Screen Replacement, Keyboard: stap 5, afbeelding 1 van 1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion DV1000 Screen Replacement: stap 6, afbeelding 1 van 2 HP Pavilion DV1000 Screen Replacement: stap 6, afbeelding 2 van 2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
  7. HP Pavilion DV1000 Screen Replacement, Media Keys: stap 7, afbeelding 1 van 1
    • Turn the laptop upside-down again.
  8. HP Pavilion DV1000 Screen Replacement: stap 8, afbeelding 1 van 2 HP Pavilion DV1000 Screen Replacement: stap 8, afbeelding 2 van 2
    • Turn the laptop right-side up. Open the screen and tilt it all the way back.
    • Locate the media keys.
    • Gently lift up the media key strip using the plastic pry tool.
    • If there is too much resistance when prying, stop and search for cause of the resistance. Do not force the media keys.
  9. HP Pavilion DV1000 Screen Replacement, Screen: stap 9, afbeelding 1 van 1
    • Remove the rubber inserts with the spudger.
    • Note: When reassembling, notice that the two lower rubber pieces are flatter than the four rubber pieces located at the top of the screen.
    • Remove the screws behind the rubber inserts.
  10. HP Pavilion DV1000 Screen Replacement: stap 10, afbeelding 1 van 2 HP Pavilion DV1000 Screen Replacement: stap 10, afbeelding 2 van 2
    • Carefully pry loose the screen casing with a plastic prying tool.
  11. HP Pavilion DV1000 Screen Replacement: stap 11, afbeelding 1 van 2 HP Pavilion DV1000 Screen Replacement: stap 11, afbeelding 2 van 2
    • Remove the plug by prying it loose with the spudger.
    • Pulling the plug with your fingers could be potentially dangerous unless you are wearing work gloves.
  12. HP Pavilion DV1000 Screen Replacement: stap 12, afbeelding 1 van 1
    • Remove the single screw marked in the image.
    • Be careful not to break the clips or pull any wires.
  13. HP Pavilion DV1000 Screen Replacement: stap 13, afbeelding 1 van 3 HP Pavilion DV1000 Screen Replacement: stap 13, afbeelding 2 van 3 HP Pavilion DV1000 Screen Replacement: stap 13, afbeelding 3 van 3
    • Remove the 4 screws marked in the picture.
    • Support the back cover and set it down on the desk. Do not pull off the back cover.
  14. HP Pavilion DV1000 Screen Replacement: stap 14, afbeelding 1 van 2 HP Pavilion DV1000 Screen Replacement: stap 14, afbeelding 2 van 2
    • Remove the screws on each side of the screen. There are four screws on each side.
    • Remove the screen.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Tyler Latour
266 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014 Lid van UMass Dartmouth, Team 6-7, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G7
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 19
Altijd: 3,413
