Ga door naar hoofdinhoud
HP Pavilion DM4 Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion DM4 Hard Drive  Replacement, Hard drive: stap 1, afbeelding 1 van 2 HP Pavilion DM4 Hard Drive  Replacement, Hard drive: stap 1, afbeelding 2 van 2
    • Unlock and remove the battery pack.
  2. HP Pavilion DM4 Hard Drive  Replacement: stap 2, afbeelding 1 van 3 HP Pavilion DM4 Hard Drive  Replacement: stap 2, afbeelding 2 van 3 HP Pavilion DM4 Hard Drive  Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the hidden screws covered by the battery pack and remove the panel to find more hidden screws.
  3. HP Pavilion DM4 Hard Drive  Replacement: stap 3, afbeelding 1 van 3 HP Pavilion DM4 Hard Drive  Replacement: stap 3, afbeelding 2 van 3 HP Pavilion DM4 Hard Drive  Replacement: stap 3, afbeelding 3 van 3
    • Unscrew the hidden screws in order to remove the hard drive cover.
    Screws were not removable on my machine. So, I would replace the word “remove” with “loosen” to avoid chance for cross-threading. otherwise, these directions were EXCELLENT.
    Vincent Juliano - Antwoord
  4. HP Pavilion DM4 Hard Drive  Replacement: stap 4, afbeelding 1 van 1
    • Pull out the tab to remove the hard drive.
  5. HP Pavilion DM4 Hard Drive  Replacement: stap 5, afbeelding 1 van 3 HP Pavilion DM4 Hard Drive  Replacement: stap 5, afbeelding 2 van 3 HP Pavilion DM4 Hard Drive  Replacement: stap 5, afbeelding 3 van 3
    • Take the hard drive out and pull the connector from it.
    • In order to disconnect the hard drive, grab the hard drive and cord then gently pull the hard drive away from the cord.
  6. HP Pavilion DM4 Hard Drive  Replacement: stap 6, afbeelding 1 van 1
    • Replace the hard drive.
    • Do not take apart the hard drive if you want it to run anything at all!
    thanks that was helpful
    Mhamad MC - Antwoord
    One more thing here is that you have to remove four screws that attach the little metal/plastic sleeve to the actual drive, and then slide the old drive out of the sleeve and the new one back in. Thanks for the guide.
    Evan - Antwoord
Conclusie
8 andere personen hebben deze handleiding voltooid.
Één opmerking
I need to replace the hard drive and was wondering how large can the DM4 handle. It is currently 578Gb and it would be great for 1 or 2 TB. Thanks
epascual1960 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 29
Altijd: 7,871
