Inleiding
If your HP Pavilion DM3-3010US screen display is showing limited or no visibility, you may have a broken screen and will need it replaced. This guide will take you step-by-step in replacing your laptop screen.
Wat je nodig hebt
Place the laptop upside down on a stable surface and locate the battery ejection switch.
Release the hinges by removing the three Phillips PM2.5x7.0 screws and hinge covers that secure it to the base.
Remove the two rubber screw covers and the two Phillips PM2.0×4.0 screws at the bottom of the enclosure. This will give you access to the internal components.
To detach the display bezel, flex the inside edges on the top, bottom, left, and right sides until it is fully detached. Then, lift it away from the rest of the screen enclosure.
Next, remove the four Phillips 2.0×3.0 screws at each corner that secure the display panel to the enclosure. Then, you can remove the hinges on each side.
Remove the display panel cable by releasing the adhesive strip. Then, you can safely disconnect the display panel cable from its port.
You can also view this maintenance and service guide provided by HP here: http://h10032.www1.hp.com/ctg/Manual/c02...
Één andere persoon heeft deze handleiding voltooid.
