Ga door naar hoofdinhoud
HP Pavilion DM3-3010US Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion DM3-3010US Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Flip laptop over to back with the battery facing downwards.
    • The battery is the silver cylinder located on the bottom of the laptop.
  2. HP Pavilion DM3-3010US Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Locate switch for battery ejection.
    • Battery ejection switch is located just above the left side of the battery.
  3. HP Pavilion DM3-3010US Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove battery by sliding the battery ejection switch to the right and pulling the battery away from the laptop.
  4. HP Pavilion DM3-3010US Hard Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion DM3-3010US Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Using a plastic opening tool, remove the large square casing located on the bottom right side of the laptop.
    • The hard drive will be visible once the casing has been removed.
  5. HP Pavilion DM3-3010US Hard Drive Replacement: stap 5, afbeelding 1 van 2 HP Pavilion DM3-3010US Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Using a Phillips #0 Screwdriver, remove each of the six Phillips #0 screws.
    • Four screws are located on each corner of the hard-drive.
    • Two screws are located on the right side of the battery slot.
  6. HP Pavilion DM3-3010US Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Remove old hard drive from its slot and replace with new hard drive, sticker side facing up.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 1,833
