Ga door naar hoofdinhoud
HP Pavilion 17-g192dx Screen Replacement
Wat je nodig hebt
  1. HP Pavilion 17-g192dx Screen Replacement, Battery: stap 1, afbeelding 1 van 3 HP Pavilion 17-g192dx Screen Replacement, Battery: stap 1, afbeelding 2 van 3 HP Pavilion 17-g192dx Screen Replacement, Battery: stap 1, afbeelding 3 van 3
    • Turn off the laptop.
    • Slide the battery lock to the right until you see the open lock symbol.
  2. HP Pavilion 17-g192dx Screen Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery release to the left until the battery pops up.
    • This may require significant force.
  3. HP Pavilion 17-g192dx Screen Replacement: stap 3, afbeelding 1 van 2 HP Pavilion 17-g192dx Screen Replacement: stap 3, afbeelding 2 van 2
    • Lift the battery up.
  4. HP Pavilion 17-g192dx Screen Replacement, Screen: stap 4, afbeelding 1 van 2 HP Pavilion 17-g192dx Screen Replacement, Screen: stap 4, afbeelding 2 van 2
    • Using the metal spudger, remove the 2 plastic screw covers at the bottom corners of the screen.
  5. HP Pavilion 17-g192dx Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 7mm screws with a Philips #00 screwdriver.
  6. HP Pavilion 17-g192dx Screen Replacement: stap 6, afbeelding 1 van 3 HP Pavilion 17-g192dx Screen Replacement: stap 6, afbeelding 2 van 3 HP Pavilion 17-g192dx Screen Replacement: stap 6, afbeelding 3 van 3
    • Use a plastic opening tool to remove the plastic cover surrounding the screen by running the tool around the edge.
    • It may be helpful to start with the metal spudger then transition to the plastic opening tool because you will need the metal tip get in initially.
  7. HP Pavilion 17-g192dx Screen Replacement: stap 7, afbeelding 1 van 3 HP Pavilion 17-g192dx Screen Replacement: stap 7, afbeelding 2 van 3 HP Pavilion 17-g192dx Screen Replacement: stap 7, afbeelding 3 van 3
    • Remove the four 4 mm screws holding the back to the display assembly with a Philips #00 screwdriver.
    • Remove the two 3mm screws holding the back cover to the display assembly with a Philips #00 screwdriver.
    • Lay the cover on the workspace carefully as not to damage the wires still connected to it.
  8. HP Pavilion 17-g192dx Screen Replacement: stap 8, afbeelding 1 van 1
    • Unplug the wire connected to the display assembly by gently pulling on it.
    • Tape may be holding it in place.
  9. HP Pavilion 17-g192dx Screen Replacement: stap 9, afbeelding 1 van 2 HP Pavilion 17-g192dx Screen Replacement: stap 9, afbeelding 2 van 2
    • Remove the four 3mm screws connecting the display assembly to the metal framework with a Philips #00 screwdriver.
    • It may be helpful to have someone else support the screen while you remove it.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 348
