Ga door naar hoofdinhoud
HP Pavilion 17-f127ds Speakers Replacement
Wat je nodig hebt
  1. HP Pavilion 17-f127ds Speakers Replacement, Battery: stap 1, afbeelding 1 van 3 HP Pavilion 17-f127ds Speakers Replacement, Battery: stap 1, afbeelding 2 van 3 HP Pavilion 17-f127ds Speakers Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Speakers Replacement, Keyboard: stap 2, afbeelding 1 van 2 HP Pavilion 17-f127ds Speakers Replacement, Keyboard: stap 2, afbeelding 2 van 2
    • Flip your laptop over on a firm surface.
    • Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
    • Flip your laptop back over.
  3. HP Pavilion 17-f127ds Speakers Replacement: stap 3, afbeelding 1 van 3 HP Pavilion 17-f127ds Speakers Replacement: stap 3, afbeelding 2 van 3 HP Pavilion 17-f127ds Speakers Replacement: stap 3, afbeelding 3 van 3
    • Using the opening tools, separate the keyboard from the laptop by prying it from the base along the sides of the laptop.
    • With your fingers, disconnect the keyboard connector and the connector cable from the motherboard.
    • Be careful not to lift the keyboard too high because it might rip off the connectors.
    • Carefully remove the keyboard.
  4. HP Pavilion 17-f127ds Speakers Replacement, Speakers: stap 4, afbeelding 1 van 2 HP Pavilion 17-f127ds Speakers Replacement, Speakers: stap 4, afbeelding 2 van 2
    • Disconnect the tape connecting the WLAN module to the main board.
    • With a Phillips #0 screwdriver remove the remaining screw holding the speaker in place.
  5. HP Pavilion 17-f127ds Speakers Replacement: stap 5, afbeelding 1 van 2 HP Pavilion 17-f127ds Speakers Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the speakers from the main board.
    • Lift away the speakers, they are connected with a wire.
Conclusie
Stephen Brown
201 Reputatie
2 handleidingen geschreven
UW Tacoma, Team S3-G1, Liner Fall 2017 Lid van UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
5 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 382
