Ga door naar hoofdinhoud
HP Pavilion 17-f127ds Optical Drive Replacement
Wat je nodig hebt
  1. HP Pavilion 17-f127ds Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: stap 1, afbeelding 2 van 3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: stap 2, afbeelding 1 van 2 HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: stap 2, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the screw holding the Optical Drive in place. It is located near the center and vents of the laptop.
    • Use a spudger to help unseat the drive. Pull the drive out from the laptop.
  3. HP Pavilion 17-f127ds Optical Drive Replacement: stap 3, afbeelding 1 van 1
    • If you need to replace the bracket on the Optical drive, remove the two Phillips #0 screws holding the bracket in place. The bracket can be placed on the new drive.
Conclusie
Stephen Brown
201 Reputatie
2 handleidingen geschreven
UW Tacoma, Team S3-G1, Liner Fall 2017 Lid van UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
5 Leden
4 handleidingen geschreven
Één opmerking
I can’t remove the HP Pavilion 17-x016ds Optical Drive. NEED HELP. Is it necessary to remove it in order to remove bottom panel to replace HDD with SSD? Also can’t remove bottom panel.
Nick Koriakin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 12
Altijd: 908
