Ga door naar hoofdinhoud
HP Pavilion 17-f004dx Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion 17-f004dx Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before you remove the battery, make sure the laptop is powered off.
    • Slide the black battery latches inward to remove the battery.
  2. HP Pavilion 17-f004dx Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery out towards you while your fingers are still holding the latches in place.
  3. HP Pavilion 17-f004dx Hard Drive Replacement, CD Drive: stap 3, afbeelding 1 van 1
    • Remove one 7 mm screw with a Phillips #1 screwdriver.
  4. HP Pavilion 17-f004dx Hard Drive Replacement: stap 4, afbeelding 1 van 3 HP Pavilion 17-f004dx Hard Drive Replacement: stap 4, afbeelding 2 van 3 HP Pavilion 17-f004dx Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Use a metal spudger to push the CD drive out of its slot for removal.
  5. HP Pavilion 17-f004dx Hard Drive Replacement, Front Panel: stap 5, afbeelding 1 van 1
    • Remove fifteen 7 mm screws with a Phillips #1 screwdriver.
  6. HP Pavilion 17-f004dx Hard Drive Replacement: stap 6, afbeelding 1 van 2 HP Pavilion 17-f004dx Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Remove the thin plastic cover using the flat metal spudger to expose another screw.
    • Remove one 7 mm screw with a Phillips #0 screwdriver.
  7. HP Pavilion 17-f004dx Hard Drive Replacement: stap 7, afbeelding 1 van 2 HP Pavilion 17-f004dx Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Use a metal spudger to remove the rubber "feet" to expose two screws.
  8. HP Pavilion 17-f004dx Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • Underneath each rubber foot, there is a screw.
    • Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
  9. HP Pavilion 17-f004dx Hard Drive Replacement: stap 9, afbeelding 1 van 1
    • Remove the two black end caps to expose more screws.
    • The end caps will require some force to remove.
  10. HP Pavilion 17-f004dx Hard Drive Replacement: stap 10, afbeelding 1 van 1
    • Remove the following six screws with a Phillips #1 screwdriver:
    • Two 7 mm screws.
    • Two 7 mm screws.
    • Two 4.8 mm screws.
  11. HP Pavilion 17-f004dx Hard Drive Replacement: stap 11, afbeelding 1 van 1
    • Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
  12. HP Pavilion 17-f004dx Hard Drive Replacement: stap 12, afbeelding 1 van 2 HP Pavilion 17-f004dx Hard Drive Replacement: stap 12, afbeelding 2 van 2
    • Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
  13. HP Pavilion 17-f004dx Hard Drive Replacement: stap 13, afbeelding 1 van 1
    • Partially lift the top cover from the enclosure.
  14. HP Pavilion 17-f004dx Hard Drive Replacement: stap 14, afbeelding 1 van 2 HP Pavilion 17-f004dx Hard Drive Replacement: stap 14, afbeelding 2 van 2
    • Remove the ribbon connecting the power button to the motherboard.
  15. HP Pavilion 17-f004dx Hard Drive Replacement: stap 15, afbeelding 1 van 2 HP Pavilion 17-f004dx Hard Drive Replacement: stap 15, afbeelding 2 van 2
    • Remove the ribbon connecting the mousepad to the motherboard.
  16. HP Pavilion 17-f004dx Hard Drive Replacement: stap 16, afbeelding 1 van 2 HP Pavilion 17-f004dx Hard Drive Replacement: stap 16, afbeelding 2 van 2
    • Remove the ribbon connecting the keyboard to the motherboard.
    • You may now fully lift the front panel from the rest of the laptop.
  17. HP Pavilion 17-f004dx Hard Drive Replacement, Hard Drive: stap 17, afbeelding 1 van 1
    • Lift the black retaining bar that holds down the two hard drive ribbons to unlock them.
  18. HP Pavilion 17-f004dx Hard Drive Replacement: stap 18, afbeelding 1 van 1
    • Gently pull the ribbons out.
  19. HP Pavilion 17-f004dx Hard Drive Replacement: stap 19, afbeelding 1 van 1
    • Lift the hard drive out from the enclosure.
  20. HP Pavilion 17-f004dx Hard Drive Replacement: stap 20, afbeelding 1 van 3 HP Pavilion 17-f004dx Hard Drive Replacement: stap 20, afbeelding 2 van 3 HP Pavilion 17-f004dx Hard Drive Replacement: stap 20, afbeelding 3 van 3
    • Pull the rubber casing away from the hard drive.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Allan Soria
623 Reputatie
4 handleidingen geschreven
UC Davis, Team 1-4, Oliver Fall 2016 Lid van UC Davis, Team 1-4, Oliver Fall 2016
UCD-OLIVER-F16S1G4
4 Leden
8 handleidingen geschreven
Één opmerking
Thank you. Couldn’t figure out why those end caps wouldn’t budge. Dang hidden screws! Kudos!
Shaun Krug - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 22
Altijd: 6,361
