Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Open the laptop.
Remove the two stickers on the lower left and right-hand corner of the laptop screen.
Using a Phillips #0 screwdriver, remove the two 5 mm screws in the lower left and right-hand corner of the laptop screen.
Place a spudger or opening tool between the laptop screen and the plastic laptop frame.
Apply light pressure to the spudger to separate the plastic laptop frame covering the edges of the laptop screen.
These silver pieces cover the laptop hinges and will need to be removed as well.
Using a Phillips #0 screwdriver, remove the four 4 mm screws in each corner of the laptop screen.
Using a Phillips #0 screwdriver, remove the four 3 mm screws on the side of the frame, one in each corner.
