Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Move the battery lock switch to the right to unlock. The battery release button will unlock the battery from the computer.
The battery release button is located above the the battery.
The battery will unlock from the computer.
Remove the unlocked battery from the computer.
Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
Remove seven 6.5 mm screws using a Phillips #0 screwdriver.
Remove four 3.0 mm screws located in the charger port using a Phillips #0 screwdriver.
Pull and remove the disk drive.
Remove two 3.00 mm screws on the inside of the disk drive using a Phillips screwdriver.
Apply firm pressure inside the release port using a narrow tool such as a screw driver or tweezers.
Flip device over so that the cover is facing towards you
Open device. The keyboard should be separate from the inside panel.
Detach the keyboard's cable connector from the motherboard.
