Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Use this guide is need to replace the keyboard of your HP Pavilion 17-e146us. The keyboard is the component of the laptop used to type. If the keyboard is faulty certain letters or portions of the keyboard may not work, and therefore it is difficult to type when necessary. This guide will show how to replace a faulty/broken keyboard with a new keyboard. Please be aware that the keyboard is attached to the motherboard and is not an easy process to remove.
  1. Turn the device over.
    • Turn the device over.
  2. Move the battery lock switch to the right to unlock. The battery release button will unlock the battery from the computer. The battery release button is located above the the battery.
    • Move the battery lock switch to the right to unlock. The battery release button will unlock the battery from the computer.
    • The battery release button is located above the the battery.
  3. The battery will unlock from the computer.
    • The battery will unlock from the computer.
    • Remove the unlocked battery from the computer.
  4. Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver. Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver. Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
    • Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
  5. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  6. Remove the HP protect smart ventilation case.
    • Remove the HP protect smart ventilation case.
    • The smart ventilation is a part of the back cover of the device
  7. Remove seven  6.5 mm screws using a Phillips #0 screwdriver.
    • Remove seven 6.5 mm screws using a Phillips #0 screwdriver.
    • Remove four 3.0 mm screws located in the charger port using a Phillips #0 screwdriver.
  8. Pull and remove the disk drive. The disk drive is located on the left side of the device when it is turned over.
    • Pull and remove the disk drive.
    • The disk drive is located on the left side of the device when it is turned over.
    • Remove two 3.00 mm screws on the inside of the disk drive using a Phillips screwdriver.
  9. Apply firm pressure inside the release port using a narrow tool such as a screw driver or tweezers.
    • Apply firm pressure inside the release port using a narrow tool such as a screw driver or tweezers.
    • The release port releases the keyboard.
  10. Flip device over so that the cover is facing towards you
    • Flip device over so that the cover is facing towards you
  11. Open device. The keyboard should be separate from the inside panel. If the keyboard does not automatically pop out, use a spudger or opening tool along the edge of the front panel and the keyboard to pop the keyboard out. Detach the  keyboard's cable connector from the motherboard.
    • Open device. The keyboard should be separate from the inside panel.
    • If the keyboard does not automatically pop out, use a spudger or opening tool along the edge of the front panel and the keyboard to pop the keyboard out.
    • Detach the keyboard's cable connector from the motherboard.
Conclusie
Emma Neumann
629 Reputatie
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 154
