Ga door naar hoofdinhoud
HP Pavilion 17 TS Rear Cover Replacement
Wat je nodig hebt
  1. HP Pavilion 17 TS Rear Cover Replacement, Battery: stap 1, afbeelding 1 van 3 HP Pavilion 17 TS Rear Cover Replacement, Battery: stap 1, afbeelding 2 van 3 HP Pavilion 17 TS Rear Cover Replacement, Battery: stap 1, afbeelding 3 van 3
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS Rear Cover Replacement, Rear Cover: stap 2, afbeelding 1 van 3 HP Pavilion 17 TS Rear Cover Replacement, Rear Cover: stap 2, afbeelding 2 van 3 HP Pavilion 17 TS Rear Cover Replacement, Rear Cover: stap 2, afbeelding 3 van 3
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
Conclusie
Sean Croft
739 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 1-6, Miles Spring 2016 Lid van UMass Dartmouth, Team 1-6, Miles Spring 2016
UMASSD-MILES-S16S1G6
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 458
