Ga door naar hoofdinhoud
HP Pavilion 15-p214dx Headphone Jack Replacement
Wat je nodig hebt
  1. HP Pavilion 15-p214dx Headphone Jack Replacement, Disk Drive: stap 1, afbeelding 1 van 3 HP Pavilion 15-p214dx Headphone Jack Replacement, Disk Drive: stap 1, afbeelding 2 van 3 HP Pavilion 15-p214dx Headphone Jack Replacement, Disk Drive: stap 1, afbeelding 3 van 3
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Headphone Jack Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-p214dx Headphone Jack Replacement: stap 2, afbeelding 2 van 2
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
  3. HP Pavilion 15-p214dx Headphone Jack Replacement, Top Cover: stap 3, afbeelding 1 van 1
    • Using a magnetic screwdriver with a Philips #0 head, remove all of the visible screws on your laptop's bottom face. These screws are all about 7.5mm long.
  4. HP Pavilion 15-p214dx Headphone Jack Replacement: stap 4, afbeelding 1 van 2 HP Pavilion 15-p214dx Headphone Jack Replacement: stap 4, afbeelding 2 van 2
    • Remove the 5.5mm screws holding the computer's end caps in place. The end caps are located to the left and right of the battery.
    • These screws are normally hidden underneath the end caps' rubber feet, which are not shown in the pictures. To remove these, gently pry them out of their slots with a plastic opening tool or a flathead screwdriver.
  5. HP Pavilion 15-p214dx Headphone Jack Replacement: stap 5, afbeelding 1 van 3 HP Pavilion 15-p214dx Headphone Jack Replacement: stap 5, afbeelding 2 van 3 HP Pavilion 15-p214dx Headphone Jack Replacement: stap 5, afbeelding 3 van 3
    • Lift both end caps from their respective corners.
    • Use a Philips #0 screwdriver to remove the 4.3mm screw that is underneath both end caps.
  6. HP Pavilion 15-p214dx Headphone Jack Replacement: stap 6, afbeelding 1 van 3 HP Pavilion 15-p214dx Headphone Jack Replacement: stap 6, afbeelding 2 van 3 HP Pavilion 15-p214dx Headphone Jack Replacement: stap 6, afbeelding 3 van 3
    • Use a Philips #0 screwdriver to remove the three 5.5mm screws in on the edge of the disk drive slot.
    • These three screws are missing from the pictures.
  7. HP Pavilion 15-p214dx Headphone Jack Replacement: stap 7, afbeelding 1 van 1
    • Flip your computer so that the bottom is now on the surface. Open the laptop like you normally would if you were about to use it.
    • Use a plastic opening tool to separate the top cover from the bottom cover.
    • Be careful when prying the cover off since it is susceptible to bending and cracking.
    • There are several cables connecting the top cover to the computer's motherboard that need to be disconnected before the cover can be completely removed.
  8. HP Pavilion 15-p214dx Headphone Jack Replacement: stap 8, afbeelding 1 van 2 HP Pavilion 15-p214dx Headphone Jack Replacement: stap 8, afbeelding 2 van 2
    • While lifting the top cover, undo the clip holding the keyboard cable in place.
    • Slide the cable out of its port.
  9. HP Pavilion 15-p214dx Headphone Jack Replacement: stap 9, afbeelding 1 van 1
    • Undo the clip holding the touchpad cable in place.
    • Remove the touchpad cable from its port.
  10. HP Pavilion 15-p214dx Headphone Jack Replacement: stap 10, afbeelding 1 van 2 HP Pavilion 15-p214dx Headphone Jack Replacement: stap 10, afbeelding 2 van 2
    • Undo the clip holding the power button cable in place.
    • Disconnect the power button cable from its port.
    • Gently lift the top cover to remove it from the computer.
  11. HP Pavilion 15-p214dx Headphone Jack Replacement, Headphone Jack / USB Port: stap 11, afbeelding 1 van 3 HP Pavilion 15-p214dx Headphone Jack Replacement, Headphone Jack / USB Port: stap 11, afbeelding 2 van 3 HP Pavilion 15-p214dx Headphone Jack Replacement, Headphone Jack / USB Port: stap 11, afbeelding 3 van 3
    • Undo the clip holding the small circuit cable.
    • Gently pull the cable out from the clip.
  12. HP Pavilion 15-p214dx Headphone Jack Replacement: stap 12, afbeelding 1 van 3 HP Pavilion 15-p214dx Headphone Jack Replacement: stap 12, afbeelding 2 van 3 HP Pavilion 15-p214dx Headphone Jack Replacement: stap 12, afbeelding 3 van 3
    • Using a magnetic screwdriver with a Philips #0 head, remove both screws that are holding down the circuit These screws are all about 5.5mm long.
  13. HP Pavilion 15-p214dx Headphone Jack Replacement: stap 13, afbeelding 1 van 3 HP Pavilion 15-p214dx Headphone Jack Replacement: stap 13, afbeelding 2 van 3 HP Pavilion 15-p214dx Headphone Jack Replacement: stap 13, afbeelding 3 van 3
    • Once the circuit is unmounted gently remove the circuit board to be replaced.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Patrick Seaver
1.001 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team S2-G1, Simcock Spring 2019 Lid van UMass Dartmouth, Team S2-G1, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 364
