Ga door naar hoofdinhoud
HP Pavilion 15-p214dx Hard Drive Replacement
Wat je nodig hebt
  1. HP Pavilion 15-p214dx Hard Drive Replacement, Disk Drive: stap 1, afbeelding 1 van 3 HP Pavilion 15-p214dx Hard Drive Replacement, Disk Drive: stap 1, afbeelding 2 van 3 HP Pavilion 15-p214dx Hard Drive Replacement, Disk Drive: stap 1, afbeelding 3 van 3
    • Place your laptop on a flat surface with the bottom facing upwards. The HP logo should be facing downwards.
    • Locate the disk drive screw. It is a 7mm screw that can be found to the upper left on label on the bottom of the computer and is marked with a disk drive symbol.
    • Remove this screw using a Philips #0 screwdriver.
  2. HP Pavilion 15-p214dx Hard Drive Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-p214dx Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Place your thumbnail between the disk drive exterior and your laptop's bottom cover.
    • If your nail is not long enough to do this, you can use a prying tool instead.
    • Pull outwards to slide the disk drive out of its slot.
    • Due to how the disk drive's slot is constructed, the drive must be properly aligned to fit back in. It may take a couple attempts to properly align it.
  3. HP Pavilion 15-p214dx Hard Drive Replacement, Top Cover: stap 3, afbeelding 1 van 1
    • Using a magnetic screwdriver with a Philips #0 head, remove all of the visible screws on your laptop's bottom face. These screws are all about 7.5mm long.
  4. HP Pavilion 15-p214dx Hard Drive Replacement: stap 4, afbeelding 1 van 2 HP Pavilion 15-p214dx Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Remove the 5.5mm screws holding the computer's end caps in place. The end caps are located to the left and right of the battery.
    • These screws are normally hidden underneath the end caps' rubber feet, which are not shown in the pictures. To remove these, gently pry them out of their slots with a plastic opening tool or a flathead screwdriver.
  5. HP Pavilion 15-p214dx Hard Drive Replacement: stap 5, afbeelding 1 van 3 HP Pavilion 15-p214dx Hard Drive Replacement: stap 5, afbeelding 2 van 3 HP Pavilion 15-p214dx Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Lift both end caps from their respective corners.
    • Use a Philips #0 screwdriver to remove the 4.3mm screw that is underneath both end caps.
  6. HP Pavilion 15-p214dx Hard Drive Replacement: stap 6, afbeelding 1 van 3 HP Pavilion 15-p214dx Hard Drive Replacement: stap 6, afbeelding 2 van 3 HP Pavilion 15-p214dx Hard Drive Replacement: stap 6, afbeelding 3 van 3
    • Use a Philips #0 screwdriver to remove the three 5.5mm screws in on the edge of the disk drive slot.
    • These three screws are missing from the pictures.
  7. HP Pavilion 15-p214dx Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • Flip your computer so that the bottom is now on the surface. Open the laptop like you normally would if you were about to use it.
    • Use a plastic opening tool to separate the top cover from the bottom cover.
    • Be careful when prying the cover off since it is susceptible to bending and cracking.
    • There are several cables connecting the top cover to the computer's motherboard that need to be disconnected before the cover can be completely removed.
  8. HP Pavilion 15-p214dx Hard Drive Replacement: stap 8, afbeelding 1 van 2 HP Pavilion 15-p214dx Hard Drive Replacement: stap 8, afbeelding 2 van 2
    • While lifting the top cover, undo the clip holding the keyboard cable in place.
    • Slide the cable out of its port.
  9. HP Pavilion 15-p214dx Hard Drive Replacement: stap 9, afbeelding 1 van 1
    • Undo the clip holding the touchpad cable in place.
    • Remove the touchpad cable from its port.
  10. HP Pavilion 15-p214dx Hard Drive Replacement: stap 10, afbeelding 1 van 2 HP Pavilion 15-p214dx Hard Drive Replacement: stap 10, afbeelding 2 van 2
    • Undo the clip holding the power button cable in place.
    • Disconnect the power button cable from its port.
    • Gently lift the top cover to remove it from the computer.
  11. HP Pavilion 15-p214dx Hard Drive Replacement, Hard Drive: stap 11, afbeelding 1 van 2 HP Pavilion 15-p214dx Hard Drive Replacement, Hard Drive: stap 11, afbeelding 2 van 2
    • Open the clip holding the USB connector cable in place, then slide the cable out of the clip.
    • Open the clip that holds the hard drive cable in place, then remove the cable from that port.
    • Tilt the hard drive so that it slopes down to the right, then pull it out of the computer.
    • You should handle the hard drive carefully, since dropping, shaking, or exposing the drive to static can cause damage.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Patrick Seaver
1.001 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team S2-G1, Simcock Spring 2019 Lid van UMass Dartmouth, Team S2-G1, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 1,347
