Ga door naar hoofdinhoud
HP Pavilion 15-p214dx Battery Replacement
Wat je nodig hebt
  1. HP Pavilion 15-p214dx Battery Replacement, Battery: stap 1, afbeelding 1 van 2 HP Pavilion 15-p214dx Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the battery lock (the switch at the upper left corner of the laptop's underside) to the right until it clicks into place.
  2. HP Pavilion 15-p214dx Battery Replacement: stap 2, afbeelding 1 van 2 HP Pavilion 15-p214dx Battery Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery release latch (the upper right-hand switch on the laptop's bottom) to the left.
    • While holding the latch in place, remove the battery from the laptop's battery bay.
    • When inserting a battery into the battery bay, the battery release latch does not need to be held open.
Conclusie
To reassemble your device, follow these instructions in reverse order. Opening the battery release latch is not required to plug the battery back in.
Patrick Seaver
1.001 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team S2-G1, Simcock Spring 2019 Lid van UMass Dartmouth, Team S2-G1, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 571
