Inleiding
If your keyboard no longer works on your HP Pavilion 15-p046nr, you’ve come to the right place. This guide will walk you through how to replace your notebook’s keyboard. You may need to change your keyboard if the keys no longer respond on your keyboard. You will need a magnetic project mat, Phillips 00 screwdriver, and plastic opening tool for this replacement. Before you get started, be sure to completely disconnect power from your device.
Wat je nodig hebt
Flip the laptop over so the bottom is facing up.
Place your finger on the top left-hand slide button with the lock symbol.
Slide the button to the right so that an unlocked symbol is visible.
Remove screw covers from the hinge covers on the upper left and right side.
Unscrew one 7 mm screw from each hinge cover using the Phillips #00 screwdriver.
Remove hinge covers by pulling up and out on the top of the cover.
