Ga door naar hoofdinhoud
HP Pavilion 15-p046nr Disk Drive Replacement
Wat je nodig hebt
  1. HP Pavilion 15-p046nr Disk Drive Replacement, Battery: stap 1, afbeelding 1 van 3 HP Pavilion 15-p046nr Disk Drive Replacement, Battery: stap 1, afbeelding 2 van 3 HP Pavilion 15-p046nr Disk Drive Replacement, Battery: stap 1, afbeelding 3 van 3
    • Flip the laptop over so the bottom is facing up.
    • Place your finger on the top left-hand slide button with the lock symbol.
    • Moving the slide does require some force.
    • Slide the button to the right so that an unlocked symbol is visible.
  2. HP Pavilion 15-p046nr Disk Drive Replacement: stap 2, afbeelding 1 van 3 HP Pavilion 15-p046nr Disk Drive Replacement: stap 2, afbeelding 2 van 3 HP Pavilion 15-p046nr Disk Drive Replacement: stap 2, afbeelding 3 van 3
    • Place your finger or thumb on the top right-hand slide with the battery symbol visible.
    • Slide the button to the left.
    • Moving the slide will require some force.
    • Lift the battery off the computer with your thumb.
    • You will not need to slide the right button with the battery to reinstall the battery.
  3. HP Pavilion 15-p046nr Disk Drive Replacement, Disk Drive: stap 3, afbeelding 1 van 3 HP Pavilion 15-p046nr Disk Drive Replacement, Disk Drive: stap 3, afbeelding 2 van 3 HP Pavilion 15-p046nr Disk Drive Replacement, Disk Drive: stap 3, afbeelding 3 van 3
    • Remove one 7 mm, Phillips #00 screw from the back panel.
    • Open the disk drive by gently pulling on the drive.
    • Pull the disk drive out and away from the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 229
